SCP to F5 question
Hi everyone,
Very basic stuff question for sure.., I’m writing a script to backup UCS config files regularly from a UNIX system through SCP. I have generated a private/public key pair with ssh-keygen on my server for root account and copied the id_rsa.pub key in the “authorized_keys” file on target F5 (BIG-IP 1600) to avoid being prompted for password.
However, it is not working. Everytime I run the scp commnad I’m asked for the root password. Is root login through SSH disabled in F5?, what am I doing wrong?
Activating the debug option on scp I’m getting this trace
debug1: Authentications that can continue: publickey,keyboard-interactive,hostbased debug1: Next authentication method: publickey debug1: Offering public key: /root/.ssh/id_rsa debug1: Authentications that can continue: publickey,keyboard-interactive,hostbased debug1: Trying private key: /root/.ssh/id_dsa debug1: Next authentication method: keyboard-interactive <<<<<<<<<<<<<<<< Password: debug1: Authentication succeeded (keyboard-interactive). <<<<<<<<<<<<<<<<<< and the remote copy completes OK.
Any ideas?, Thanks in advance,
Moog
If you SSH from the F5 to your UNIX server, are you prompted to trust the host key? If so, trust it and then try again.
Still no joy, I’m prompted for remote server’s password
scp root@X.X.X.X:/var/f5backups/test /var/tmp
The authenticity of host ‘X.X.X.X (X.X.X.X)’ can’t be established. RSA key fingerprint is “some_key_fingerprint” Are you sure you want to continue connecting (yes/no)? yes Warning: Permanently added ‘X.X.X.X’ (RSA) to the list of known hosts. SomeServer …
root@X.X.X.X’s password:
Well, now your boxes should trust each other. Does the key login from your UNIX server to F5 work now?
i think you shouldn’t use root. Create another user with admin+bash rights and use that one. In v11.x should work without changing the configuration, as long as the authorized_keys file is properly set. 404 Page not found | BIG-IP Documentation
