Well, I got some odd results when I tried to discover the F5 device again. The F5 wizard said it was successful. But, there is an error in the event viewer that seems to indicate otherwise (event ID 301, source “F5 Events”):
Failed to discover device at address: 10.41.52.27
Network-related failure has occurred: [Category]GZip:[Type]SendFailure;LastError=SSL IO Error 487181392: SYSCALL:
F5Networks.Protocols.iQuery.iQueryException: [Category]GZip:[Type]SendFailure;LastError=SSL IO Error 487181392: SYSCALL:
at F5Networks.Protocols.iQuery.RawIQuerySocket.CoreSendRaw(String rawCommand)
at F5Networks.Protocols.iQuery.iQuerySocketBase.<>c__DisplayClass5.b__4()
at F5Networks.ProgressTracking.Tracer.<>c__DisplayClass1.b__0()
at F5Networks.ProgressTracking.Tracer.DoActionWithTryFinally[TReturnResult](GenericVoidHandler`1 activeCode, VoidVoidDelegate preCode, VoidGenericHandler`1 postCode, VoidVoidDelegate postCodeSuccess, VoidGenericHandler`1 postCodeFailure)
at F5Networks.ProgressTracking.Tracer.DoActionWithTryFinally(VoidVoidDelegate activeCode, VoidVoidDelegate preCode, VoidGenericHandler`1 postCode, VoidVoidDelegate postCodeSuccess, VoidGenericHandler`1 postCodeFailure)
at F5Networks.ProgressTracking.Tracer.DoActionWithTryFinally(VoidVoidDelegate activeCode, VoidVoidDelegate preCode, VoidVoidDelegate postCodeSuccess, VoidGenericHandler`1 postCodeFailure)
at F5Networks.ProgressTracking.Tracer.TraceCall(VoidVoidDelegate activeCode, String action, String area, String category, Int32 id)
at F5Networks.Protocols.iQuery.iQuerySocketBase.SendRaw(String rawCommand)
at F5Networks.Protocols.iQuery.TransactionalIQuerySocket._FlushSendBuffer(Boolean sendData)
at F5Networks.Protocols.iQuery.TransactionalIQuerySocket.SendRaw(String rawCommand)
at F5Networks.ManagementPack.Services.DeviceMonitor._UpdateStatisticRulesOnDevice(Device device, iQueryConnection connection, Dictionary`2 collectionRules, IList`1 objectsRemoved, Boolean throwOnNetworkError)
at F5Networks.ManagementPack.Services.DeviceMonitor._InitializeRulesOnDevice(DeviceDiscoveredEventArgs successContext, Device device)
at F5Networks.ManagementPack.Services.DeviceMonitor._CompleteDiscovery(DeviceDiscoveredEventArgs successContext)
at F5Networks.ManagementPack.Services.DeviceMonitor._DeviceDiscovered(Object sender, DeviceDiscoveredEventArgs successContext)
What do you guys think is going on?
