Requirement - To get a script for S/W code version 11.5/11.6 - “Scheduling a script that checks if Config is Sync between Active and Standby LTM/GTM, In case if config is not SYNC then it should send an alert on e-mail ID.”
I do not think that there are any snmp traps that could capture the status of the configuration-sync, else it would have been easier to get alerts through the monitoring tool, like NNMi etc.
you want one written for you? wouldn’t it be a nice learning experience to built one yourself?
it doesn’t seem like that hard a script:
- login in to box
- check prompt
- if not in sync send email
these would be things that you can find examples of quite easily with google or any other search engine.
