Save on Automatic Sync Option
What will happen if i dont enable Save on Automatic Sync option will the config not be written bigconfig file on peer?
Please see K14624: Configuring the Automatic Sync feature to save the configuration on the remote devices:
“When the Automatic Sync feature is enabled for a device group, the BIG-IP system automatically synchronizes configuration changes, but does not save the changes to the configuration files on each device in the device group.”
“In some cases, you might want to configure the Automatic Sync feature to update the running configuration and save the configuration to the configuration files on each device in the sync group. Depending on your BIG-IP version, you can do this by setting the save-on-auto-sync option to true for the Root trust domain or device group.”
so if i dont enable this option and after auto sync will the config not be saved to config file on peer untill i use save command on peer?
Correct. You will need to save the config to file manually.
