Saml token convert to jwt
Hello,
I create a iRule for convert saml token to JWT (json web token). It works well but I get a signatur error. I try many option and formats. But nothing works. I’m shure you can help me easily.
I have creat a working access Profile with saml. Bigip is SP and an external IdP. Here my iRule.
when ACCESS_ACL_ALLOWED {
        set hamacsha256 secret
       set secret_key "secret"
        get data from saml Session (APM->Manage Sessions-> Variables -> View)
       set user [ACCESS::session data get session.saml.last.nameIDValue]
       set sub [ACCESS::session data get session.saml.last.attr.name./EmployeeID]
       set nbf [ACCESS::session data get session.saml.last.validityNotBefore]
       set exp [ACCESS::session data get session.saml.last.validityNotOnOrAfter]
       set email [ACCESS::session data get session.saml.last.attr.name./identity/claims/emailaddress]
       set surname [ACCESS::session data get session.saml./Common/xyz_auth_ag.attr.name./identity/claims/surname]
       set givenname [ACCESS::session data get session.saml./Common/xyz_auth_ag.attr.name./identity/claims/givenname]
       set aud [ACCESS::session data get session.saml.last.assertionIssuer]
       set gpid [ACCESS::session data get session.saml.last.attr.name./GPID]
        Name of the cookie
       set cookie_name "xyz-JWT"
        set cookie header
       set cookie_header "[b64encode "{\r\n \"alg\": \"HS256\", \r\n \"typ\": \"JWT\"\r\n}"]"
        set cookie payload
       set cookie_payload "[b64encode "{\r\n \"user\": \"$user\",\r\n \"sub\": \"$sub\",\r\n \"nbf\": \"$nbf\",\r\n \"exp\": \"$exp\",\r\n \"email\": \"$email\",\r\n \"surname\": \"$surname\",\r\n \"givenname\": \"$givenname\",\r\n \"aud\": \"$aud\",\r\n \"gpid\": \"$gpid\"\r\n}"]"
       set cookie data for signatur
       set cookie_data [concat "[b64encode [URI::encode $cookie_header]].[b64encode [URI::encode $cookie_payload]]"]
        test some other version
       set cookie_data "[URI::encode [b64encode $cookie_header]]\".\"[URI::encode [b64encode $cookie_payload]]"
       set cookie_data "[URI::encode $cookie_header]\".\"[URI::encode $cookie_payload]]"
       set cookie_data $cookie_header"."$cookie_payload
       log local0. "cookie_data $cookie_data"
       create signatur
       set cookie_sig "[CRYPTO::sign -alg hmac-sha256 -key $secret_key $cookie_data]"
       convert signatur in some version
       set cookie_sig_b64 "[b64encode $cookie_sig]"
       set cookie_sig_b64_url "[URI::encode $cookie_sig_b64]"
       set cookie_sig_url_b64 "[b64encode $cookie_sig_url]"
       log local0. "sig_b64= $cookie_sig_b64"
       log local0. "sig_b64_url= $cookie_sig_b64_url"
       log local0. "sig_url_b64= $cookie_sig_url_b64"
       verify signatur
       if { [CRYPTO::verify -alg hmac-sha256 -key $secret_key -signature $cookie_sig $cookie_data] } {
           log local0. "Data verified"
       create full JWT
       set cookie "$cookie_header.$cookie_payload.$cookie_sig_url_b64"
       HTTP::cookie insert name $cookie_name value $cookie
       log local0. "$cookie_name $cookie"
    send to client
    when HTTP_RESPONSE {
If I verify the cookie with jwt.io (webseite). I get alway a signatur error. All other works. The json notation for signatur is
HMACSHA256(
      base64UrlEncode(header) + "." +
      base64UrlEncode(payload),
      secret
    ) secret base64 encoded
I think I have a mistake in format for cookie_data. In the version you can see some of my tests. How can help me?
Cheers, NetSnoopy
Hello,
i found my mistake and now it’s working. Here is the working iRule
     get date from Saml Session
    set sub [ACCESS::session data get session.saml.last.attr.name.http://xxxx.de/EmployeeID]
    set email [ACCESS::session data get session.saml.last.attr.name.http://schemas.xmlsoap.org/ws/2005/05/identity/claims/emailaddress]
    set surname [ACCESS::session data get session.saml./Common/kosmos-uat_APM_Test_act_saml_auth_ag.attr.name.http://schemas.xmlsoap.org/ws/2005/05/identity/claims/surname]
    set givenname [ACCESS::session data get session.saml./Common/kosmos-uat_APM_Test_act_saml_auth_ag.attr.name.http://schemas.xmlsoap.org/ws/2005/05/identity/claims/givenname]
    set gpid [ACCESS::session data get session.saml.last.attr.name.http://xxxx.de/xxxx-User-GPID]
    generate JWT
    set jwt_header "[b64encode "{\r\n \"alg\": \"HS256\", \r\n \"typ\": \"JWT\"\r\n}"]"
    set jwt_payload "[b64encode "{\r\n \"user\": \"$user\",\r\n \"sub\": \"$sub\",\r\n \"nbf\": \"$nbf\",\r\n \"exp\": \"$exp\",\r\n \"email\": \"$email\",\r\n \"surname\": \"$surname\",\r\n \"givenname\": \"$givenname\",\r\n \"aud\": \"$aud\",\r\n \"gpid\": \"$gpid\"\r\n}"]"
    set jwt_data "$jwt_header.$jwt_payload"
    set jwt_sig "[b64encode [CRYPTO::sign -alg hmac-sha256 -key $secret_key $jwt_data]]"
    set jwt "$jwt_header.$jwt_payload.$jwt_sig"
    log local0. "JWT $jwt"
    if { [info exists jwt] }{
    HTTP::header insert Authorization "Bearer $jwt"
In this case the JWT will only send to Server but not to Client. If you want this also to Client and the follow lines
I hope I can help someone with this example.
Cheers, NetSnoopy
Sounds good NetSnoopy!
thank you very much! Only one question: you are using “nbf” as timestamp but I saw that in the JWT spec they suggest to use “iat”, any reason?
Cheers Pomello
UPDATE: Sorry, I found the difference between iat and nbf :wink:
Thank you
