Can you please share which IDPs require the use of these attributes? They are optional attributes that are currently not supported by SLO configuration of APM. Please open a case with F5 support and request an RFE to support them, and provide as much information as possible, including the IDPs that use them(and any information as to why they are used). Thanks!
The IdP is a large public authority (state population registry). The IdP is based on Shibboleth.
The request identifies the principal to be logged out using a NameID element, as well as providing a SessionIndex element to uniquely identify the session being closed.
“LogoutRequest NameID should include NameQualifier and/or SPNameQualifier provided by the IdP in it’s Response NameID. Some IdPs such as Shibboleth might not otherwise be able find the correct session to logout.”
These correspond to the following BIG-IP MCP settings:
apm aaa saml-idp-connector
Adds this configuration to apm aaa saml-idp-connector
name-qualifier
Specifies the security or administrative domain of the external
IdP. This value usually matches IdP Entity ID.
apm aaa saml
name-id-policy-sp-name-qualifier
Optionally specifies that the assertion subject's identifier be
returned in the namespace of an SP other than the requester, or in
the namespace of a SAML affiliation group of SPs. This attribute
can be a session variable.
apm sso saml-sp-connector
Adds this configuration to apm sso saml-sp-connector
sp-name-qualifier
Optionally qualifies an identifier with the name of a service
provider or affiliation of providers.
apm sso saml
name-qualifier
Specifies the security or administrative domain of the IdP (this
BIG-IP system). This value usually matches IdP Entity ID.
Is the Name-Identifier Policy Format available in version 13.1.0.8 I dont see this option but I need this setting to be on version 2.0. I do see the Service Provider Name Qualifier option.
