SAML request signing and digests with SHA256?
In 11.5.0 APM (Jan 2014) APM started to support SHA256 for SAML assertions.
424572APM SAML can now operate with other systems using either or both of these groups of algorithms: RSA-SHA256/RSA-SHA512 XML signature algorithms SHA256/SHA512 digest algorithms. It continues to sign its own SAML messages (AuthnRequests and Assertions) using RSA-SHA1.
Does APM still (in June 2016) use only SHA1 for SAML request signing and digests? In the F5 SAML AuthRequests we have http://www.w3.org/2000/09/xmldsigsha1" />
We have a major IdP no longer supporting SHA1, they want SHA256: http://www.w3.org/2001/04/xmlencsha256" />).
Are there plans for the SAML SHA256 signing and digests?
Looks like SAML Authnrequest signed using SHA2 is now supported in 12.1.0.
I’m currently testing on my lab.
Thanks Yann. If you can check the outgoing SAML request with SAML Tracer for example. If signing and digests are using SHA256, the AuthnRequest xml should have elements something similar to: ) instead of the old SHA1: This will tell the IdP the used signature / digest methods
Just an extract of my testing on 12.1.0 :
https://sptest.e-xpertsolutions.com
                arAENl5+aZIMW6tf8BSxGwhWP0u0rzsXYwdiQUKMvlU=
For me, it’s now supported.
Thanks Yann, obviously it is not supported in 11.5.3 branch, which my customer is using..
