Saml Logout from IDP and redirect
Hi I My BigIP is SP My Logout URI is /logout when client request /logout I create a irule for logout and close APM session
when HTTP_REQUEST {             if { [string tolower [HTTP::uri]] contains "/logout" } {                 ACCESS::session remove                ACCESS::respond 302 Location "http://OtherHost.com/" "Set-Cookie" "MRHSession=0; expires=Tuesday, 29-Mar-1970 00:15:00 GMT" "Connection" "Close"             }    }
but after client won’t connect again after 1 min it automatically connected without credentials because i think the IDP doesn’t do logout POST? how can I fix that ?
try this:
ACCESS::respond 302 noserver Location "/vdesk/hangup.php3"
return
If you set correctly apm part (SLS and SLR) you will be redirect automaticly to your IDP in order to logout then return to app.
Keep me in touch.
Regards
