We have a SAML IdP setup that has been working well for us but I have run into an SP that I am unable to authenticate for. When performing SAML Tracer, I found that all working SPs are using a GET message to the F5. For the new SP, it is using a POST. The behavior for the browser is to authenticate and then nothing. It is just like when you send an invalid SAMLRequest. Has anyone seen this and know what I may be doing wrong? Or is this a limitation of the F5 APM module?
We had a similar issue with POST vs Redirect. We were authenticating users via transparent Kerberos. After authentication, the SAML data was missing from the request when using a POST. A Redirect binding worked fine. You should be able to see the actual AuthNRequest in SAML Tracer or other tool. Does it still exist after authentication to the APM?
