SAML IDP-initiated without webtop
so i have 1 SP initiated SAML setup and working. i have another request to setup an IDP initiated SAML connection. i have get it to work successfully following the guide but after signing into the F5 the users have to click the link in the webtop. from research i know i should be able to send them directly to the correct SAML resource but i have not been able to figure it out. any help would be great?
this is the guide i followed 404 Page not found | BIG-IP Documentation
yes i have the SAML working for both my SP-initiated and IDP-initiated. when a user uses the SP-initiated URL they are taken directly to the service providers site. this is how i want the IDP to work as well so users do not have to manually click on the IDP-initiated resource once authenticated.
That’s what I’m saying. Your IdP visual policy could look like this:
start -> [auth] -> allow
Apply the SAML IdP config as an SSO profile to that access policy (directly) - no webtop, no resource assignment. You just need to make sure that at some point in the visual policy you populate that Assertion Subject Value session variable.
but if i remove the advanced resource assign from the VPE my SP-initiated SAML application stops working. maybe i am missing something but i followed the F5 guide for supporting both SP and IDP initited SAML.
my setup is as follows: 1 virtual server 1 access profile 1 access policy 2 saml local IDP services 2 saml external SP Connectors 2 saml resources
Are you doing SP and IdP on a single VIP?
An SP-initiated SAML auth doesn’t require a resource assignment either. It’s just:
start -> SAML Auth -> allow
That’s assuming the SAML SP is on one VIP and your IdP is on another.
yes i was doing both SP-initiated and IDP initiated on the same VIP. this was according to the guide and made sense so i only have 1 url for saml.
If you use a single VIP, then you do indeed need to use a resource assignment.
I was definitely not listening when you said “IdP-initiated without the webtop”, so I addressed that in your other post. Otherwise, yes I would typically separate IdP and SP functions into separate VIPs. If you think about it, SAML is a federation protocol. If you need SSO to different applications on the same VIP, you can do that without SAML.
well both are sending saml assertions. so its not just single sign on. i just have 1 that is SP-initiated and the other i have to initiate (IDP-initiated) i just cannot afford to hand out public IP addreses for each as im sure there will be more later.
Are you at least using different host names? You could possibly move the visual policy flow through different paths - one for SP-init
start -> [hostname evaluate] -> SAML auth -> allow
and another for IdP-init
start -> [hostname evaluate] -> [auth] -> advanced resource assign
But generally speaking, you may only need the one IdP VIP and combining all of the SPs into one VIP would be trivial.
same hostname based on the f5 guide for setting up SP and IDP SAML. but the entity for each is differnt resulting in different URL. for example: https://sso.example.com/SPinitiated https://sso.example.com/IDPinitiated
so in my case i would either have to identify them by the URL or go back and define seperate hostnames it sounds like. i have seen several posts on this and most use an irule to send it one way or the other but someting like below did not work for me either. im starting to wonder if the URL i am using to access the IDP-initiated service is wrong. shouldnt https://sso.example.com/IDPinitiated be able to get me to the IDP resource?
when ACCESS_POLICY_COMPLETED { if { [ACCESS::session data get session.server.landinguri] == “/saml/idp/profile/redirectorpost/sso” } { log local0. “SP initiated SAML detected, not sending redirect” } else { ACCESS::respond 302 Location “/saml/idp/res?id=[ACCESS::session data get session.assigned.resources.saml]” log local0. “IDP initiated SAML detected, sending redirect” } }
You’re almost there. Here is what you need to do in terms of iRUles. The gist is that you need to name your IDP resource and redirect to the proper webtop resource. You can try to automate it like you did to dynamically populate respond string, or you can define them statically in the switch statement - that way you can have more user-friendly setup, I believe. Keep in mind that in this case we assume you use Common partition(thus /Common/IDPresourceName reference - substitute that for what your resource is really defined as)
when HTTP_REQUEST priority 30  {
 if {[ACCESS::policy result] eq "allow"; }
      switch -glob [HTTP::path] {
      "/IDPResource";
                HTTP::respond 302 Location "/saml/idp/res?id=/Common/IDPResourceName"
                return
` ACCESS Policy Response used to provide IdP Initiated SAML for users that have not logged in yet
when ACCESS_POLICY_COMPLETED priority 30 {
     switch -glob [ACCESS::session data get session.server.landinguri] {
          "/IDPResource"
                    ACCESS::respond 302 Location "/saml/idp/res?id=/Common/IDPResourceName"
                    return
:wink:
thanks i modified the irule a bit but so far this is working for me: when ACCESS_POLICY_COMPLETED { if { [ACCESS::session data get session.server.landinguri] starts_with “/saml/idp/profile/redirectorpost/sso” } { log local0. “SP initiated SAML detected, not sending redirect” } if { [ACCESS::session data get session.server.landinguri] starts_with “/URLtoIDPinitiated” } { log local0. [ACCESS::session data get session.assigned.resources.saml] ACCESS::respond 302 Location “https://sso.example.com/saml/idp/res?id=/Common/SAML_Resource” log local0. “IDP initiated SAML detected, sending redirect” } else { log local0. “Nothing Matched land on portal” } }
now if i could just setup single sign on to my SP initiated SAML application i could add that link to the portal also.
Sure - keep in mind that you really probably should replicate the logic in both HTTP_REQUEST and ACCESS_POLICY_COMPLETED events if you are not ending the session right away. If your use case is going to grow in a way that you’ll be providing IDP services for multiple SPs, you’d certainly want your users to authenticate once and then be SSOed into their APPs seamlessly. If you use just that snippet that you’re using, it will work only when the user does not have a valid session with the IDP yet.
so my working irule looks like this:
if { [ACCESS::session data get session.server.landinguri] starts_with "/saml/idp/profile/redirectorpost/sso" } {
    log local0. "SP initiated SAML detected, not sending redirect"
if { [ACCESS::session data get session.server.landinguri] starts_with "/SAMLURL" } {
    ACCESS::respond 302 Location "https://sso.example.com/saml/idp/res?id=/Common/SAML_Resource"
    log local0. "IDP initiated SAML detected, sending redirect"
    log local0. "Nothing Matched land on portal"
looks like yours handle the 302 redirect but not the SP-initiated.  do i need to add those lines to both httprequest and accesspolicy completed sections?
