I’ve setup an SAML iDP with F5 and it’s working without issues, Running on 11.6 software.
In the setup there’s an access profile that forces all clients to do two-factor authentication when authenticating to the SAML iDP. There’s now a a requirement that some of the SAML SP’s would like to lower the authentication to one-factor (username/password) but some of the apps still require two-factor. I’ve tried to research and it seems that in version 12.0 there’s a new attribute ‘AuthContextClassRef’ but I’m having a hard time finding any explanations, manuals or guides how (and if) I could use this feature to solve my problem.
If the AuthContextClassRef could be used to force, or even step-up, the user to do two-factor authentication when accessing certain applications are there any references how to create the VPE policy (and other SAML config) for following scenarios:
- SP initiated connection, SP requests 2-factor auth
- SP initiated connection, SP requests 1-factor auth
- SP initiated connection, user has already authenticated with 1-factor and has a session, but the SP requires 2-factor auth.
- iDP initiated connection, either 1 or 2 factor
Any help is appreciated. Currently if the AuthContextClassRef option and version 12 doesn’t solve the problem, I’m thinking of creating a separate IDP and moving the apps requesting 1-factor auth to the new IDP and leaving other apps on the IDP that has 2-factor in the VPE policy flow.
