SAML Federation
Is it possible to setup a SAML configuration where one Big-IP is both IdP and SP?
Technically, I don’t see why not. You could authenticate the user, give him an assertion, and this user could use the assertion to connect to another service in this same unit.
So, my assumption is yes, it does support having both in the same unit.
I could not find any information in the documentation that says you can’t do that.
Here is the solution about SMAL 2.0:
