F5 acts as SP - looking for a way to perform saml auth with external idp and pass saml attributes/roles (receives from the idp)into application as jwt token for authentication … i didn’t find any similar deployments … i assume an irule or irule lx will do the trick
Yes, you can use iRulesLX to create JWTs, and then pass them to the application via HTTP header insert(either in per-request access policy or via iRule).
