Hello,
I’m looking for a way to configure my APM with SAML 2.0 to support Outlook desktop app.
I saw on a post from Lorie MacVittie mentioning that F5 added support for SAML ECP profiles.
https://devcentral.f5.com/articles/f5-synthesis-supersizing-application-access-services
I’m currently running 11.6.0 but found no trace of such configuration in APM.
Does someone implemented SAML support for Outlook desktop app ?
Best Regards
Yann,
Yes, we have supported Office 365 Outlook Desktop app with SAML since version 11.3. Check out the iApp here: DevCentral - An F5 Technical Community
When you deploy it, it implements the necessary ECP functionality via iRule enhancement to accommodate Office 365 requirements.
FYI, the iApp that Michael mentioned above is now available as part of the iApp Templates (1.0.0.230) package on downloads.f5.com. We recommend using this template because it is officially supported by F5.
thanks
Mike
Hi Yann, ECP Profile ist now supported in Version 12.0
