SAM Auth Double Prompt Using Exchange iApp
Good morning to all!
In our design, we’re looking to process both SAM %DOMAIN%\%USERNAME% and UPN %USERNAME%@%DOMAIN% auth through LDAP Auths and Queries. To sum up our environment, we have multiple SAM NetBIOS domains, but each user account’s UPN name resolves back to a single domain name. All domains exist within a single AD Forest.
I have constructed the following Access Policy which branches users based on the way they entered their account while adding some extra functionality you can note following the LDAP Query:
With the use of the Exchange iApp v1.3.0, the preferred logon type for the Outlook Web App is Forms. Using this type, we are able to auth users using UPN credentials without issue, but are being prompted with a secondary auth prompt from the internal server when using SAM credentials.
We opened a support case, and the workaround provided was to modify the %APP%_select_sso_irule2 to select NTLM auth instead of forms. This resulted in SAM auth working properly, but we later noticed that UPN auth is now prompting the user with a secondary prompt.
I believe the issue we’re seeing can be corrected within the SSO Credential Mapping object, but I can’t seem to figure out the logic to send the correct username to the internal server without getting inundated with “domain exists within the username” lines in the APM log.
Any ideas? Thanks!!
Cory, would it be easier to convert all user sessions to either UPN or SAM. You’re already doing an AD query so you can override the session.logon.last.username with the UPN or SAM. It would simplify your VPE configuration and should resolve your double prompt issue.
OK - After putting in some significant time, I’ve figured out how to solve this issue. We faced multiple symptoms that led to this particular problem, BUT I sincerely welcome the folks that write the Exchange iApp and associated documentation to provide feedback if I’m incorrect with my statements below.
ISSUE 1
Our Exchange CAS servers were configured to only accept Basic authentication in order to function properly with Forefront TMG. This has now been re-configured to utilize Forms-Based Auth as the Exchange iApp expects.
ISSUE 2
We have multiple internal domains within a single forest, so we cannot login with only a username. The username for OWA MUST be presented in a %DOMAIN%\%USERNAME% or %USERNAME%@%DOMAIN% format. Since the iApp has configured the Access Policy to Split Domain from Username, I reconfigured the Form Parameters field of the Forms-Client Initiated SSO Configuration to POST %{session.ldap.last.attr.userPrincipalName} instead of %{session.sso.token.last.username} for the username field. Obviously, you’ll need to make sure you’re running the prerequisite Query within the Access Policy to pull this variable so it can be leveraged.
ISSUE 3
The documented SSO Select iRule within the Exchange iApp Deployment Guide for OWA had a couple clarifications we had to modify (see p87 in the http://www.f5.com/pdf/deployment-guides/microsoft-exchange-iapp-v1_3-dg.pdf guide):
when RULE_INIT {
   replace exchange_forms_sso here with your forms-based SSO name
   set static::OWA_FORM_BASE_SSO_CFG_NAME "exchange_forms_sso"
when ACCESS_ACL_ALLOWED {
   set req_uri [HTTP::uri]
   selects the forms-based SSO when Outlook Web Access is detected
   if { $req_uri contains "/owa/&reason=0" } {
      WEBSSO::select $static::OWA_FORM_BASE_SSO_CFG_NAME
   unset req_uri
When you modify line 3 to set the forms_sso configuration you created, MAKE SURE to use the full path (“/Common/exchange_forms_sso” instead of “exchange_forms_sso”). We couldn’t get to anything further without it configured that way.
Also; using the IE Developer tools, I noticed that the /owa/&reason=0 URI noted on line 8 of the iRule was never presented to us from our Exchange 2010 environment. Therefore, the Forms SSO was never invoked. I changed this value from “/owa/&reason=0” to “/owa/auth” and everything was perfect after that.
To sum up, here’s what my iRule looked like after all was said and done:
when RULE_INIT {
   set static::OWA_FORM_BASE_SSO_CFG_NAME "/Common/exchange_forms_sso"
   if { $req_uri contains "/owa/auth" } {
   unset req_uri
Again, I am BRAND NEW to this, so I ask any of the moderators/experts to provide feedback to this answer. While this solution works, I am still concerned that I could be causing more issues downstream that I haven’t uncovered yet. For those who are also seeing this issue, I hope this helps you out!
Thanks all, Cory
Hi Cory, thanks for the input. Regarding issues 1 and 2, you are correct. The iApp expects forms auth when using APM, although we have added smart card auth as an option in the next version.
Also, the iApp defaults to a simpler APM configuration than you require; we find this to be sufficient for the majority of customers. We did also add the ability to choose your own APM profile, rather than just accepting the defaults, in hopes of providing a little more flexibility.
About 3: The v1.3.0 iApp should have created an iRule that looked like this:
        WEBSSO::select [set foo /Common/exchange_2013.app/exchange_forms_sso]
    unset req_uri
It looks like the deployment guide is lagging the iApp, and we’ll get that corrected. Did the iApp create an iRule like the one from the guide, or was it formatted like the one above?
thanks
Mike
Mike -
You are correct! I went through and created a new App from the ground up, and indeed it created the following:
        WEBSSO::select [set foo /Common/THISISATESTAPP.app/exchange_forms_sso]
    unset req_uri
I think the issue in this case is I started from the 1.2.0 iApp and this time around I had manually created all the AAA/APM related functions out of the Deployment Guide and selected them from the iApp config.
YES; I would definitely appreciate the update to the SSO Select iRule on p78 of that Deployment Guide! While you’re in there, I also noticed that the OA Persistence iRule on p82 has a discrepancy between the variables set and leveraged on lines 16 and 17. The ActiveSync Persist iRule also has mixed up variables on p78 in lines 3 and 4.
Sorry to dump all that on you at once, but I already feel like it’s Christmas today!! :slightly_smiling_face:
Thanks Mike for all your help!
-Cory
