Safe RDP connection
Hi all! I apologize if I am writing a question in the wrong section! I need your advice! I am using RDP connection, I wanted to know if there are any tools to make the connection safe?
Hello! If you need to work with data that requires special attention, you can look here https://www.helpwire.app/blog/secure-remote-access/ for a detailed description of the technologies that are used for security.
