Rules format - upgrade from 4.x to 9.x
We are in the process of upgrading from version 4.x to 9.x
Can someone help me and tell whether i have to do any changes to my Rule from version 4.x before i put it n the version 9.x?
thanks in advance for any help.
if (server_port == 80) {
redirect to “https://%h/%u”
else {
use pool Notes8-Test-Pool
thanks,
how about this one? Also, is there a way that i can put line comments withing iRule code? whatg would be the syntax?
thanks in advance
when CLIENT_ACCEPTED {
set tmm_auth_ssl_cc_ldap_sid [AUTH::start pam default_ssl_cc_ldap]
when CLIENTSSL_CLIENTCERT {
AUTH::cert_credential $tmm_auth_ssl_cc_ldap_sid [SSL::cert 0]
AUTH::authenticate $tmm_auth_ssl_cc_ldap_sid
SSL::handshake hold
when AUTH_SUCCESS {
if {$tmm_auth_ssl_cc_ldap_sid eq [AUTH::last_event_session_id]} {
SSL::handshake resume
when AUTH_FAILURE {
reject
when AUTH_WANTCREDENTIAL {
reject
when AUTH_ERROR {
reject
thanks for help. I tried to install this and got an error, so what needs to be fixed?
01070151:3: Rule [notes8_1-redirect-rule] error:
line 1: [wrong args] [when HTTP_REQUEST ]
line 2: [undefined procedure: if { [TCP::local_port] eq “80” }
{ HTTP::redirect “https://[HTTP::host][HTTP::uri]”
else { pool Notes8-Test-Pool }
] [{ if { [TCP::local_port] eq “80” }
iRules is standard TCL so you can use the ‘’ to delimit a line that is a comment. Documentation for the TCL language is at this link:
Click here
-Joe
