I am trying to write a iRule to massage RTSP response data, I found a event named “RTSP_RESPONSE_DATA” in wiki, I tried to add a new iRule with this event but BIGIP prompted
"01070151:3: Rule [RTSP_response] error:
line 1: [unknown event (RTSP_RESPONSE_DATA)] [when RTSP_RESPONSE_DATA {
As is stated at the top of the RTSP page in the Wiki, the RTSP functionality in iRules currently requires an EA license to enable RTSP logic functions on your BIG-IP. Once you have that, you’ll be able to use the general RTSP commands in iRules.
As far as RTSP_RESPONSE_DATA goes, in particular, this will behave much like CLIENT_DATA, in that the event will not be valid until you’ve collected at least part of the RTSP payload with the RTSP::collect command.
