Hi Team,
After a long gap, again coming back to the same topic(Dividing or routing traffic through SNAT or Self-IP) where I got the concept:
when CLIENT_ACCEPTED { if { [class match [IP::client_addr] equals my_ip_datagroup] } { snat 1.1.1.1 } else { snat 2.2.2.2 } }
Now I wanted to relate this to three environments:
PROD: which got the enviroment’s subnet as 10.25.128.0/24 where Self IP’s are ( Floating IP: 10.25.128.99, In primary:10.25.128.98 and in secondary LTM:10.25.128.97) PREP: which got the environment’s subnet as 10.25.129.0/24 where Self IP’s are ( Floating IP: 10.25.129.99, In primary:10.25.129.98 and in secondary LTM:10.25.129.97) EDI : which got the environment’s subnet as 10.25.130.0/24 where Self IP’s are ( Floating IP: 10.25.130.99, In primary:10.25.130.98 and in secondary LTM:10.25.130.97) 1.Now Idea is to create a Data-group named PROD_ip_datagroup which will contains a source segment of 10.25.128.x and 64.x.x.x), which can only access the PROD enviroments. 2.Similarly Idea is to create a Data-group named PREP_ip_datagroup which will contains a source segment of 10.25.129.x and 64.x.x.x), which can only access the PREP enviroments. 3.Similarly Idea is to create a Data-group named EDI_ip_datagroup which will contains a source segment of 10.25.129.x and 64.x.x.x), which can only access the PREP enviroments.
Once the above created, idea is to have below:
If the Data-Group:PROD_ip_datagroup source segment matched, they are allowed to access the PROD environment( which is 10.25.128.x subnet), and the connections will come through the new planned SELF-IP, lets say 10.25.128.109. Else the connections will be through SNAT:10.25.128.99( WHICH is the floating IP).
If the Data-Group:PREP_ip_datagroup source segment matched, they are allowed to access the PROD environment( which is 10.25.129.x subnet), and the connections will come through the new planned SELF-IP, lets say 10.25.129.109. Else the connections will be through SNAT:10.25.129.99( WHICH is the floating IP).
If the Data-Group:EDI_ip_datagroup source segment matched, they are allowed to access the PROD environment( which is 10.25.130.x subnet), and the connections will come through the new planned SELF-IP, lets say 10.25.129.109. Else the connections will be through SNAT:10.25.130.99( WHICH is the floating IP).
Kindly guide how my Irule will look like.
Quick query: Let’s say in all the Data-groups, lets say we have a common source:64.x.x.x, so is there any specific condition to put to route through different SNAT’s to different environments( PROD, PREP and EDI).
Thanks and Regards
