Below is my iRule and I run into issue where it seems that the iRule only looks at the last cookie.
If I have multiple cookie in the header and the last cookie in the header is not test_a, the rule below will not work.
if (exists http_cookie(“test_a”) and http_cookie(“test_a”) contains “1”) {
use pool test_a_1_Pool
else {
if (exists http_cookie(“test_a”)) {
use pool test_a
else {
use pool regular_pool
Thanks for any help or pointer.
