Route Domains with HA
Hi, If i create a route domain on the active f5 in an active/standby HA Group, will config sync create it on the standby f5, or will i have to manually create on both.
thanks Colin
You have to create it manually on Standby. Be aware that if you configure RD on active with some floating objects (before creating RD and related non floating objects on Standby) then you will not be able to do sync - at least that was my experience in Lab (could be different for different TMOS versions but I doubt).
Piotr
