Route Domain configuration issues (VIPs down)
I have a pair of F5 VEs that I’m adding route domains and recreating the same VIPs (the VIPS are up). I have 3 interfaces [external1, external2 and internal]. I created
  • ext1%1, ext2%2; int1%1 and int2%2
  • vlan10 tagged 1.1, vlan20 tagged 1.2; vlan11 tagged 1.3, vlan21 tagged 1.3
  • route domain 1: vlan10 & vlan11; route domain 2: vlan20 & vlan21
  • pool1 node1%1, node2%1 & tcp monitor
  • pool2 node1%2, node2%2 & tcp monitor
  • VIPs: VS1%1 w/pool1 & VS2%2 w/pool2
All IP addresses for all objects are the same except the new objects have the route ID added. My non-route domains VIPs are up but my new route domain ones are down. What I’m I missing?
Missing routes in the route domains?
You can check the routing etc by using rdsh eg
rdsh 2
ping node2
