Route Domain Concern
Hi Team,
I create another route domain id 1 with Vlan_test member assigned. When i create self-ip then member it to Vlan_test. errors occurs.
Errors: 01070978:3: The vlan (/Common/Vlan_test for the specified selp IP must be one of the vlans in the associated route domain (/Common/0).
Thanks for the help!
Goldz
Either the Vlan_test is not assigned to route domain 1 (double check under the route domain config) or the self IP you are trying to create you didn’t end with %1 e.g. Self IP 192.168.0.1%1 will belong to route domain 1.
Hi AMG,
i already member the Vlan_test to route domain 1. we now already created the selp ip with %1. but during ping test, we need to add the %1. example: ping 192.168.1.1%1.
Thanks!
Goldz
On the CLI you will need to add %1 or to a route domain using 'rdsh ’ so ‘rdsh 1’ to change to route domain 1 which would allow you to run ‘ping 192.168.1.1’ without the %1.
Hi AMG,
what if, we have multiple route domain to configure, to segregate the routing. do RDSH is a solution for that for ping issues? do we have problem encouter on default routing domain 0?
Regards,
Goldz
You can use 'RDSH ’ for each route domain, so if you have route domain 2 ‘rdsh 2’ will switch you to bash shell on route domain 2.
rdexec 1 ping 10.1.1.1
will work if you don’t want to switch the RD context but just want to run a command in that route domain.
Hi Brad Parker, thanks for this command
few things need to clarify on route domain. Example we only using 1 port then configured it to tagged. we used multiple vlan tagged to that port, member it to multiple route domain id. on the side of creating of route under network, how can we member specific route to route domain group id.
Example: port1/tagged to vlan 10/selfip example 10.10.10.1%10 / route domain=10 with member vlan 10. how about the route?
Thanks!
Golden
route destination and gateway just need to have %rd added to their address like the selfip.
meaning all ip’s configured also have %rd. specially on the VIP ip address and Pool member ip address?
If it is an IP address that needs to be part of a paticular route domain you need % on the end of it. Virtual Server Addresses, route and gateway addresses, Self IPs etc.
