Route domain and Failover
Hi Techies, I am planning to setup on a pair of Ltm’s as following Partition common network-1 (route-domain-1, traffic-group-1, vlan1,2, selfip1.., forward_vs1) network-2 (route-domain-2, traffic-group-2, vlan3,4, selfip2.., forward_vs2)
network-2 (route-domain-3, traffic-group-2, vlan3,4, selfip2.., forward_vs2) HA vlan in route-domain-0
LTM1 will be active for all traffic group.
My question is about fail over . In case of monitoring object of any of the route-domain fails that particular route domain should fail over to LTM2 .Can anyone help with configuration.
resubmitting -------------------------------------------- I am planning to setup on a pair of Ltm’s as following Partition common network-1 (route-domain-1, traffic-group-1, vlan1,2, selfip1.., forward_vs1) network-2 (route-domain-2, traffic-group-2, vlan3,4, selfip2.., forward_vs2) network-3 (route-domain-3, traffic-group-2, vlan3,4, selfip2.., forward_vs2) My question is about fail over . In case of monitoring object of any of the route-domain fails that particular route domain should fail over to LTM2 .Can anyone help with configuration.
Yeah. That’s fine (With v11.4.1 upwards). You just have to make sure that all the objects for network-1 are in one traffic-group. All the objects for network-2 in another traffic-group etc. Then assign priorities for the traffic-groups
If 11.3 (i.e. versions that don’t have traffic-group member priorities), you’ll have to either manually move stuff, or try using HAGroups (Which are NOT a lot of fun).
H
