Root Folder Device Group: None
Hello
I had problems with the first time wizard whilst creating a HA cluster. So I clear all the cluster config and started again.
Now the cluster is configured but it is Sync-Only.
Seems like I lost the Device Group setting:
Under ‘System >> Platform >> Redundant Device Properties’ I get:
Under ‘System ›› Users : Partition List ›› Common’
I get Device Group : None … And the option to choose is gray-out
Can I fix this or do I need to reset VE appliances to factory and start again?
Can I reset to factory defaults without loosing the license?
Any advice will be most appreciated…
Thanks,
tmsh load sys config default still retain license file.
sol13127: Restoring the BIG-IP configuration to factory default settings (11.x)
