Hi, we’ve implemented Kerberos authentication using APM, but now that is all up and running we’d like to delegate the administration of the Visual Policy Editor and all the APM related objects (Kerberos AAA, Active Directory AAA…) to the security folks. I know that there’s a “Application Security Policy Editor” role that seems to apply only to ASM. I’d need something like the “APM administrator role”. Is there something like that? can I somehow delegate the APM administration?
I’m afraid that maybe I can’t delegate it, so I’ve thought in create a separate guest in my vCMP system so I can license the APM on that new guest. In that way I’d have my LTM guest and my APM guest, and I could give the administrator account in the APM guest to the security folks without need to handle with the “user roles” problem. But I don’t know if I can have LTM and APM in different systems, because I’ve worked only in a system where LTM and APM were licensed together, so I can reference the APM policies from the LTM Virtual Servers as a local object. If I have the APM in a separate guest from the LTM, how I’d reference the policy objects? I have search, with no luck, any deployment guide for a “one LTM with several APM” and I hav found nothing… any references?
Thanks!
