rlnclientipaddr re-write?
My engineers have given me that requirement that the http header field rlnclientipaddr always has to be populated with the real source IP of the http traffic.
I am not sure if I will be using SNAT yet for the pool these servers live in, so this will be the only way for the logging data to retain the real request IP.
I am guessing this should be set up on http_request action, but how exactly would I implement the rewrite itself?
You can create a custom HTTP profile with the option for Header to Insert configured. Set it as:
rlnclientipaddr: [IP::client_addr]
If you want LTM to remove any pre-existing HTTP headers named rlnclientipaddr, configure the Header to Erase as rlnclientipaddr.
Aaron
