RHI with Wildcard VS
i was testing RHI + BGP , i configured Vs= Certain IP & enabled route advertisement on it , after that when using the command ( vtysh then show ip route ) i found the VIP IP appeared at routing table as Kernel ( K ) route which is good .
but my target will be to inject a default route at a router & my VIP is wildcard VS ( because as i understand RHI inject route with destination = VIP ip ) . i teasted by enabling Route advertisement on this Wildcard VS but it didnot appaer on "show ip route " , i was expecting it should appear as Kernel route ?
does RHI does not support WildCard address ( default route ) ?
Hi
I’m not sure what version you are running but I believe you can redistribute the kernel routing which would suggest you can advertise any route you want; 404 Page not found | BIG-IP Documentation
