Hello people.
I have one problem
I am having problems to export a excel file, bigger than 96K. When the file is smaller than 96K the problem dosent occurs, but with files bigger than 96K the F5 send a reset packet.
In SOL5922 : Error Message: http_process_state_prepend - Invalid action EV_INGRESS_DATA during ST_HTTP_PREPEND_HEADERS
I identificated this erros, The sol said that Any response that is not compliant with RFC2616 causes this error message.
In a Httpwatch a can see that in content-disposition there is special characteres like example:
content-disposition= attachement;filename=FILE_teste_01/01/2001 10:08:01.xlsx;size=196…
Probably these special characters in content that is not compliant with RFC2616.
if that behavior can not be corrected the application side, can I solve that with some irule? irule Replace content can resolve? If someone can quote some example that would answer thank you very much
thank you very much
have you tried to log rst cause? just wondering which cause will be logged.
sol13223: Configuring the BIG-IP system to log TCP RST packets
Hello
The cause of the problem, is like the SOL said, a back end answer that not compliance with the RCF.
We are analyzing the tcpdump captures and httpwatch.
Until this moment we identify one beahvior. content-disposition there is special characteres like example:
thank you very much
You can turn off HTTP processing altogether by either removing the HTTP profile from the virtual or using the HTTP::disable command in an irule after connecting to that server.
Thompson but my Vs use http profile and cook persistence. I cant remove then
In my scenario I have no irule.
Only a VS with http profile and cookie persistence
if that behavior can not be corrected the application side, can I solve that with some irule? irule Replace content can resolve? The Vs use http profile and cook persistence.
thanks a lot
