I’ll just jump right into the good stuff. Here’s my scenario:
wget --no-check-certificate -S “https://69.80.196.153/zap?aid=10000066&sid=6&can=fffffffffffffffe ” -O /dev/null 2>&1 | grep " Location: " | grep --color “http://”
Location: https://bh.contextweb.com/bh/rtset?do=add&pid=536088&ev=4614711881901867008&rurl=http://matcher-cwb.bidder7.mookie1.com/do-association?return=ctxweb%26can=fffffffffffffffe
Location: http://matcher-cwb.bidder7.mookie1.com/do-association?return=ctxweb&can=fffffffffffffffe
Location: http://ib.adnxs.com/getuid?http://matcher-apx.bidder7.mookie1.com/appnexus?can=ffffffffffffffee%26adnxs\_uid=$UID
A customer has requested to see if the possibility exists to rewrite the location headers from http to https. The first “location: https” is the F5. We are terminating the ssl connection on the F5 and passing the connection to a pool of servers on port 80. We are using an HTTP profile to rewrite the response to https. Is it possible to rewrite the rest of the location headers in the response?
I found and tried the iRule below but didn’t work:
when HTTP_RESPONSE {
Check if response type is text
if {[HTTP::header value Content-Type] contains “text”}{
Replace http:// with https://
STREAM::expression {@http ://@https ://@}
Enable the stream filter for this response only
STREAM::enable
Hi EddieV,
Did you create a blank stream profile and apply it to the Virtual Server and create a custom HTTP Profile that has the “Response Chunking” set to “Rechunk”?
Using the default stream profile. I’m not familiar with stream at all. The F5 alerted me to enable when I applied the iRule with the stream expression.
Response chunking set to Selective
nitass
November 9, 2011, 4:02pm
4
are bh.contextweb.com , matcher-cwb.bidder7.mookie1.com and ib.adnxs.com under F5 i.e. virtual server?
wget --no-check-certificate -S "https://69.80.196.153/zap?aid=10000066&sid=6&can=fffffffffffffffe" -O /dev/null 2>&1 | grep "Location:"
Location: /zap-set?aid=10000066&sid=6&can=fffffffffffffffe
Location: /zap-set?aid=10000066&sid=6&can=fffffffffffffffe [following]
Location: https://bh.contextweb.com/bh/rtset?do=add&pid=536088&ev=4614500775662583808&rurl=http://matcher-cwb.bidder7.mookie1.com/do-association?return=ctxweb%26can=fffffffffffffffe
Location: https://bh.contextweb.com/bh/rtset?do=add&pid=536088&ev=4614500775662583808&rurl=http://matcher-cwb.bidder7.mookie1.com/do-association?return=ctxweb%26can=fffffffffffffffe [following]
Location: http://matcher-cwb.bidder7.mookie1.com/do-association?return=ctxweb&can=fffffffffffffffe [following]
Location: /do-association-set?return=ctxweb&can=fffffffffffffffe
Location: /do-association-set?return=ctxweb&can=fffffffffffffffe [following]
Location: http://ib.adnxs.com/getuid?http://matcher-apx.bidder7.mookie1.com/appnexus?can=ffffffffffffffee%26adnxs_uid=$UID
Location: http://ib.adnxs.com/getuid?http://matcher-apx.bidder7.mookie1.com/appnexus?can=ffffffffffffffee%26adnxs_uid=$UID [following]
Nitass,
I’m trying to get a definitive answer from my customer regarding that right now. Thank you for the response.
I tried to use rechunk and no success.
I’m working on restating the problem.
Looks like an answer was found and for specific instances:
if { [string tolower [HTTP::header “Location”]] contains “?http” } {
HTTP::header replace “Location” [string map -nocase {?http: ?https:} [HTTP::header “Location”]]
if { [string tolower [HTTP::header “Location”]] contains “=http” } {
HTTP::header replace “Location” [string map -nocase {=http =https} [HTTP::header “Location”]]
if { [string tolower [HTTP::header “Location”]] contains “&http” } {
HTTP::header replace “Location” [string map -nocase {&http &https} [HTTP::header “Location”]]
nitass
November 10, 2011, 5:37am
8
with http profile, stream profile will replace only http payload.
without http profile, it will replace tcp payload which includes http header.
[root@ve1023:Active] config b virtual bar list
virtual bar {
snat automap
pool foo
destination 172.28.65.152:https
ip protocol tcp
profiles {
clientssl {
clientside
myhttp {}
tcp {}
[root@ve1023:Active] config b profile myhttp list
profile http myhttp {
defaults from http
redirect rewrite all
[root@centos251 ~] cat /etc/hosts
172.28.65.152 bh.contextweb.com matcher-cwb.bidder7.mookie1.com ib.adnxs.com
[root@centos251 ~] wget --no-check-certificate -S "https://172.28.65.152/zap?aid=10000066&;sid=6&;can=fffffffffffffffe" -O /dev/null 2>&1|grep -i location
Location: https://172.28.65.152/zap-set?aid=10000066&%3bsid=6&%3bcan=fffffffffffffffe
Location: https://172.28.65.152/zap-set?aid=10000066&%3bsid=6&%3bcan=fffffffffffffffe [following]
Location: https://bh.contextweb.com/bh/rtset?do=add&%3bpid=536088&%3bev=4614500775662583808&%3brurl=http://matcher-cwb.bidder7.mookie1.com/do-association%3freturn=ctxweb6can=fffffffffffffffe
Location: https://bh.contextweb.com/bh/rtset?do=add&%3bpid=536088&%3bev=4614500775662583808&%3brurl=http://matcher-cwb.bidder7.mookie1.com/do-association%3freturn=ctxweb6can=fffffffffffffffe [following]
Location: https://matcher-cwb.bidder7.mookie1.com/do-association?return=ctxweb&%3bcan=fffffffffffffffe
Location: https://matcher-cwb.bidder7.mookie1.com/do-association?return=ctxweb&%3bcan=fffffffffffffffe [following]
Location: https://matcher-cwb.bidder7.mookie1.com/do-association-set?return=ctxweb&%3bcan=fffffffffffffffe
Location: https://matcher-cwb.bidder7.mookie1.com/do-association-set?return=ctxweb&%3bcan=fffffffffffffffe [following]
Location: https://ib.adnxs.com/getuid?http://matcher-apx.bidder7.mookie1.com/appnexus%3fcan=ffffffffffffffee6adnxs_uid=$UID
Location: https://ib.adnxs.com/getuid?http://matcher-apx.bidder7.mookie1.com/appnexus%3fcan=ffffffffffffffee6adnxs_uid=$UID [following]
virtual bar {
snat automap
pool foo
ip protocol tcp
profiles {
clientssl {
clientside
mystream {}
tcp {}
[root@ve1023:Active] config b profile mystream list
profile stream mystream {
defaults from stream
source "http://"
target "https://"
Location: https://bh.contextweb.com/bh/rtset?do=add&%3bpid=536088&%3bev=4614500775662583808&%3brurl=https://matcher-cwb.bidder7.mookie1.com/do-association%3freturn=ctxweb6can=fffffffffffffffe
Location: https://bh.contextweb.com/bh/rtset?do=add&%3bpid=536088&%3bev=4614500775662583808&%3brurl=https://matcher-cwb.bidder7.mookie1.com/do-association%3freturn=ctxweb6can=fffffffffffffffe [following]
Location: https://ib.adnxs.com/getuid?https://matcher-apx.bidder7.mookie1.com/appnexus%3fcan=ffffffffffffffee6adnxs_uid=$UID
Location: https://ib.adnxs.com/getuid?https://matcher-apx.bidder7.mookie1.com/appnexus%3fcan=ffffffffffffffee6adnxs_uid=$UID [following]
hope this helps.
nitass
November 10, 2011, 5:43am
9
just in case you want to use HTTP::is_redirect.
virtual bar {
snat automap
pool foo
ip protocol tcp
rules myrule
profiles {
clientssl {
clientside
http {}
tcp {}
[root@ve1023:Active] config b rule myrule list
rule myrule {
if {[HTTP::is_redirect]} {
HTTP::header replace Location [string map -nocase {http:// https://} [HTTP::header value Location]]
Thanks nitass. My initial use of stream was incorrect. Your second post HTTP::is_redirect is the method I ended up using.
