Folks - I seem to be struggling with getting an irule working which does the following:-
If a client hits http://irule.com I want him to end up at https://www.irule.com
http://irule.com and http://www.irule.com go to the same IP address in DNS.
There are two VS setup for www.irule.com one for port 80 and another for port 443
I have tried a variety of irules but I am not having much success.
Any pointers would be helpful.
Thanks,
JD
nitass
2
can you try something like this?
[root@ve1023:Active] config b virtual bar list
virtual bar {
destination 172.28.19.79:80
ip protocol 6
rules myrule
profiles {
http {}
tcp {}
[root@ve1023:Active] config b rule myrule list
rule myrule {
if {[string tolower [HTTP::host]] equals "irule.com"}{
HTTP::redirect "https://www.[HTTP::host][HTTP::uri]"
[root@ve1023:Active] config curl -I http://irule.com/
HTTP/1.0 302 Found
Server: BigIP
Connection: Keep-Alive
Content-Length: 0
Thanks for that, it worked a treat. I was trying to get far too complicated - sometimes the solution is right in front of you!
