Hi all, where can I find the option as in previous version that “Rewrite Redirects = All” ?
I use a rule to redirect HTTP to HTTPS :
HTTP::redirect https://[getfield [HTTP::host] “:” 1][HTTP::uri]
But it’ll redirect me to http and https several times, in the old version, I can set “Rewrite Redirects” to All in Proxy property to avoid this.
Thanks.
In v9, you can configure Rewrite Redirects functionality in the http profile(Local Traffic / Profiles / Services / HTTP): Create a new profile based on “http”, check the “Custom” box next to “Redirect Rewrite” and select something other than “None” from the dropdown:
* None: Specifies that the system does not rewrite any HTTP redirect responses.
* All: Specifies that the system rewrites the scheme to HTTPS in all HTTP redirect responses.
* Matching: Specifies that the system rewrites the scheme to HTTPS in any HTTP redirect responses in which the hostname matches that of the request.
* Nodes: Specifies that if the redirect target contains a node IP address instead of a host name, the system rewrites the scheme to HTTPS and the hostname to the VS address.
/deb
Oops, forgot to add you have to apply the newly-created profile to the HTTPS virtual server instead of the default “http” profile.
/d
Great and succeeded, thanks.
