I need to capture 500 errors and when I receive them return a preformated error page. This page will sit on a different domain (where the digital publishing team can update it quickly) and therefore I need to rewrite HOST/URI and send to different pool.
So far I have the following:
when HTTP_RESPONSE {
switch -glob [HTTP::status] {
"500" {
HTTP::header replace Host "new.domain.com"
HTTP::uri "/error"
pool /TEST/POOL_FOR_NEW_DOMAIN
Unfortunately you cannot use HTTP::uri in an HTTP_RESPONSE.
I do not want to do a 302 redirect as that would mean client would see the new domain.
Is there a simple way round this?
I know we can host page on BIG-IP (ifiles) but as mentioned - publishing team want access to the page to change wording quickly.
Since you can’t access HTTP::uri in the response, you’ll need to set a variable in HTTP_REQUEST so you can access it.
If you look at the HTTP::retry command (see the last example on that page), you may be able to retry the request and change the request so you can get a different response from another server. (You may have to add some logic in your HTTP_REQUEST event to handle whatever host/location you use in the updated request).
If you ever wanted to just return a custom payload from within your iRule, you could use something like this codeshare entry to get you started.
You originally mentioned you don’t want to use a 302 redirect for the client, but want to get the error page from somewhere your publishing team can update quickly, right? In that case, if they need a page to update on a server, the HTTP::retry would allow you to basically do a redirect that the user never sees because it’s all contained in the F5.
Otherwise if you just have custom content to return to the user, I think you can use the
HTTP::respond 200 content ""
method within HTTP_RESPONSE to send back some custom html.
You could also use a sideband connection to capture the response that is hosted on the other domain and return that as the response in place of the 500 error. DevCentral - An F5 Technical Community
Here’s another approach that doesn’t require HTTP::uri. The rule may or may not work as-is since I pulled out environment-specific stuff and inserted your new pool and host. However, it should still provide a template.
if { [HTTP::status] equals 403 || [HTTP::status] equals 404 } {
Retrieve the not-found page if the HTTP status is 403, 404
Note: Retrieving the page is a valid request, which means that the server will respond with a 200 OK.
This necessitates that we collect the payload so we can later construct a custom response with
the proper HTTP response code (404) but with the payload (HTML) from this request.
if { ![info exists retry] } {
set retry 1
HTTP::retry "GET /error/not-found/ HTTP/1.1\r\nHost:$requested_host\r\n\r\n"
if { [info exists is404] } {
if { [HTTP::status] equals 200 } {
store the payload of the not-found page if the HTTP status is 200
(this means that the error page was found on the file system)
HTTP::collect [HTTP::header Content-Length]
No error page was found in the folder. Construct a generic error page
and send it to the client.
log local0.debug "is404 true, but there's no error page on the file system. ([HTTP::status])"
HTTP::respond 404 content {
when HTTP_RESPONSE_DATA {
Construct the response with the payload of the not-found page that we collected earlier and
with the HTTP Response Code "404".
HTTP::respond 404 content [HTTP::payload] "Content-Type" "text/html"
Arie - I shoudl have made it clear - the domain will remain the same - its just the request for content that will go to the pool of content servers. So i believe SEO will remain unaltered.
