rewrite help
Hello,
I have the following irule to rewrite a url
log local0. “[IP::client_addr]:[TCP::client_port]: Original URI: [HTTP::uri]”
log local0. “urlrewrite rule”
Check if URI matches first format using scan
if {[scan [HTTP::uri] {/%/app/download.php%(.*)} a] == 1}
HTTP::uri “http://www.myserver.com/tools/app/download/vendor/language/installer$a”
===Log===
When I hit this rule i get the following error in my logs.
TCL error: urlrewritedownload HTTP_REQUEST - bad scan conversion character p while executing scan [HTTP::uri] {/app/download.php.*} a
The url I use to execute the irule is
http://www.abc.com/app/download.php?id=1140000
Thanks,
Aaron
Are you trying to append id=1140000 to the following redirect http://www.myserver.com/tools/app/download/vendor/language/installer?id=1140000?
if so then perhaps the following will work
 log local0. "[IP::client_addr]:[TCP::client_port]: Original URI: [HTTP::uri]"
 log local0. "Original Path: [HTTP::path]"
 log local0. "Original Qeury: [HTTP::query]"
 log local0. "urlrewrite rule"
 if { ([HTTP::host] eq "www.myserver.com") and ([HTTP::path] eq "/app/download.php") } {
 HTTP::redirect "http://[HTTP::host]/tools/app/download/vendor/language/installer?[HTTP::query]"
I hope this helps
CB
