Requirement is to rewrite only first uri string.
Eg. https://www.company.com/test/example/test/index.htm to https://www.company.com/testUI/example/test/index.htm
With string map syntax, all “test” in URI part are getting rewrite. also tried split uri to get the first string, set variable and then use string map, but no luck. Can someone please help with any pointer?
