Rewrite Control List Modern doesn´t work on chrome
Hello community,
Not a single application works on chrome 122.0.6261.69 64 bits (Also tested on 122.0.6261.95 64 bits), via APM access profile, when use Rewrite Control List set to “Modern” for every request. Application won’t open and browser reproduces following alerts:
The same application works perfectly well on firefox 123.0 (64-bit). Also tested with a variety of applications and frameworks and the results are the same: Won’t open with google chrome and works perfectly well on firefox.
Importante note: Access thru chrome worked perfectly a few weeks ago, it seems like some google update broke f5 modern rewrite mechanism.
Techinical information
BIGIP version: 17.1.0.3/build 0.75.4
Chrome version: 122.0.6261.69 64 bits
Firefox version: firefox 123.0 64 bits
Operating system: Ubuntu 22.04.4 LTS
High-Availability Cluster
Rewrite configuration:
Any insights/helps would be appreciated
Just to add some of information: By “Application”, I mean a portal access web application, publichsed on a webtop, with following config:
Have you tried this? K000138771: APM Portal Access stops working after upgrading Chrome to version 122+
Thank you so much, Daniel! That seems exactly what my problem is. Tomorrow morning I will try this and let you know.
Coming back here just to say it worked like a charm. Thank you so much @danielm1
