Rewrite and forward to specific pool
I have a question about rewrite and forward to specific pool based on URL accessed.
Setup:
One HTTPS VS, called VS1 with client SSL profile using certificate for .
Two pools, called Pool1 and Pool2 with one member in each pool.
In Pool1, the member is configured with port 80 and in Pool2, the member is configured with port 8443
I have used rewrite profile and policies, which are attached to the VS1
External URLs:
ExURL1: https://www.abc.com
ExURL2: https://www.abc.com/test
Internal URLs:
IntURL1: http://internal.abc.com/site1
IntURL2: https://internal.abc.com:8443/site2
Scenario:
Client connects to ExURL1, BIG-IP rewrites url to IntURL1 and forwards to Pool1. Then the client connects to ExURL2, BIG-IP rewrites url to IntURL2 and forwards to Pool2.
Question:
How can this be achieved, since IntURL2 are using SSL and there is not attached any server SSL profile to the VS.
Hope someone can point me in the right direction.
irule sample
// config
root@(ve13a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
    destination 172.28.24.10:443
    ip-protocol tcp
    mask 255.255.255.255
    profiles {
        clientssl {
            context clientside
        http { }
        serverssl-insecure-compatible {
            context serverside
        tcp { }
    rules {
        qux
    source 0.0.0.0/0
    source-address-translation {
        type automap
    translate-address enabled
    translate-port enabled
    vs-index 19
root@(ve13a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool
ltm pool pool1 {
    members {
        200.200.200.101:80 {
            address 200.200.200.101
ltm pool pool2 {
    members {
        200.200.200.111:8443 {
            address 200.200.200.111
root@(ve13a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
ltm rule qux {
when RULE_INIT {
  set static::internalhost "internal.abc.com"
  switch -glob [HTTP::uri] {
      HTTP::uri "/site1"
      SSL::disable serverside
      pool pool1
    "/test/*" {
      HTTP::uri [string map {/test/ /site2/} [HTTP::uri]]
      pool pool2
    default {
       do something
when HTTP_REQUEST_RELEASE {
  HTTP::host "${static::internalhost}:[LB::server port]"
// test1
[root@ve13a:Active:In Sync] config  ssldump -Aed -nni 0.0 port 80 or port 443 or port 8443 -k /config/ssl/ssl.key/default.key
New TCP connection 1: 172.28.24.1(33808) <-> 172.28.24.10(443)
...snipped...
1 10 1515902215.1724 (0.0035)  C>SV3.3(128)  application_data
    HEAD / HTTP/1.1
    User-Agent: curl/7.29.0
    Accept: */*
    Host: www.abc.com
New TCP connection 2: 200.200.200.14(24713) <-> 200.200.200.101(80)
1515902215.1743 (0.0015)  C>S
HEAD /site1 HTTP/1.1
Accept: */*
Host: internal.abc.com:80
// test2
[root@ve13a:Active:In Sync] config  ssldump -Aed -nnr /var/tmp/test2.cap -k /config/ssl/ssl.key/default.key
New TCP connection 1: 172.28.24.1(33824) <-> 172.28.24.10(443)
...snipped...
1 10 1515902715.2350 (0.0007)  C>SV3.3(128)  application_data
    HEAD /test/hello HTTP/1.1
    Accept: */*
    Host: www.abc.com
[root@ve13a:Active:In Sync] config  ssldump -Aed -nnr /var/tmp/test2.cap -k /var/tmp/localhost.key
New TCP connection 2: 200.200.200.14(43637) <-> 200.200.200.111(8443)
...snipped...
2 10 1515902715.2410 (0.0006)  C>SV3.1(128)  application_data
    HEAD /site2/hello HTTP/1.1
    Accept: */*
    Host: internal.abc.com:8443
here is local traffic policy (cpm) sample. by the way, i did not use rewrite profile.
// config
ltm virtual bar {
    ip-protocol tcp
    policies {
        testpolicy1 { }
    profiles {
        clientssl {
            context clientside
        http { }
            context serverside
        tcp { }
    source 0.0.0.0/0
        type automap
    vs-index 19
ltm pool pool1 {
    members {
ltm pool pool2 {
    members {
root@(ve13a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm policy testpolicy1
ltm policy testpolicy1 {
    controls { forwarding server-ssl }
    last-modified 2018-01-14:12:24:45
    requires { http }
    rules {
        testsite1 {
            actions {
                0 {
                    server-ssl
                    disable
                1 {
                    http-uri
                    replace
                    value /site1
                2 {
                    http-host
                    replace
                    value internal.abc.com
                3 {
                    forward
                    select
                    pool pool1
            conditions {
                0 {
                    http-uri
                    values { / }
        testsite2 {
            actions {
                0 {
                    http-host
                    replace
                    value internal.abc.com:8443
                1 {
                    http-uri
                    replace
                    value "tcl:[string map {/test/ /site2/} [HTTP::uri]]"
                2 {
                    forward
                    select
                    pool pool2
            conditions {
                0 {
                    http-uri
                    starts-with
                    values { /test/ }
            ordinal 1
    status published
    strategy first-match
// test1
[root@ve13a:Active:In Sync] config  ssldump -Aed -nni 0.0 port 80 or port 443 -k /config/ssl/ssl.key/default.key
New TCP connection 2: 172.28.24.1(33842) <-> 172.28.24.10(443)
...snipped...
2 10 1515904001.6202 (0.0006)  C>SV3.3(128)  application_data
    HEAD / HTTP/1.1
    Accept: */*
    Host: www.abc.com
New TCP connection 3: 200.200.200.14(3637) <-> 200.200.200.101(80)
1515904001.6211 (0.0005)  C>S
Accept: */*
// test2
[root@ve13a:Active:In Sync] config  ssldump -Aed -nnr /var/tmp/cpm2.cap -k /config/ssl/ssl.key/default.key
New TCP connection 2: 172.28.24.1(33844) <-> 172.28.24.10(443)
...snipped...
2 10 1515904108.0480 (0.0008)  C>SV3.3(128)  application_data
    Accept: */*
    Host: www.abc.com
[root@ve13a:Active:In Sync] config  ssldump -Aed -nnr /var/tmp/cpm2.cap -k /var/tmp/localhost.key
New TCP connection 3: 200.200.200.14(43617) <-> 200.200.200.111(8443)
...snipped...
3 10 1515904108.0549 (0.0004)  C>SV3.1(128)  application_data
    Accept: */*
// config
ltm virtual bar {
    ip-protocol tcp
    policies {
        testpolicy1 { }
    profiles {
        clientssl {
            context clientside
        http { }
            context serverside
        tcp { }
    source 0.0.0.0/0
        type automap
    vs-index 19
ltm pool pool1 {
    members {
ltm pool pool2 {
    members {
    requires { http }
    rules {
        testsite1 {
            actions {
                0 {
                    server-ssl
                    disable
                1 {
                    http-uri
                    replace
                    value /site1
                2 {
                    http-host
                    replace
                3 {
                    forward
                    select
                    pool pool1
            conditions {
                0 {
                    http-uri
                    values { / }
        testsite2 {
            actions {
                0 {
                    http-host
                    replace
                1 {
                    http-uri
                    replace
                2 {
                    forward
                    select
                    pool pool2
            conditions {
                0 {
                    http-uri
                    starts-with
                    values { /test/ }
            ordinal 1
    status published
// test1
...snipped...
    HEAD / HTTP/1.1
    Accept: */*
    Host: www.abc.com
Accept: */*
// test2
...snipped...
    Accept: */*
    Host: www.abc.com
...snipped...
    Accept: */*
Thanks a lot nitass. I will try both of your answers.
