what is about advantages and disadvantages of one-arm reverse proxy and two arm reverse proxy?
I am not sure about all the possible advantages/disadvantages. However, in any network design, alway use 2-arm mode as default option and 1-arm for requirements that aren’t solved by 2-arm mode. This is just a rough idea and it could vary depending on your application requirements and existing network set up.
If your network set-up doesn’t allow SNAT you should consider two armed.
Cheers,
Kees
