Hi,I have a irule like this
if {$uri matches_regex “^/(help/)”}
HTTP::redirect ]
pool cjj1
return
else{
pool cjj2
1:don’t know the true meaning of return
2:can I use
HTTP::redirect http://[HTTP::HOST][HTTP::uri]
pool cjj1
in this way?
HTTP::redirect ]
pool cjj1
return
else{
pool cjj2
2:can I use
pool cjj1
in this way?
Hi Jucao,
Return immediately exits the current EVENT. In your case if there is a match for “cjj1” it exits the event and does not further process the statement. From your posting it appears that you do not need a return statement.
I hope this helps
Bhattman
I’d also replace the regex with a more efficient string command:
if {$uri starts_with “/help/”}
As Bhattman said, you don’t need the return statement unless you have more code after the else statement.
Aaron
Hi,Bhattman hoolio
Thanks for your help
if there exist 2 events in this irule ,
when HTTP::request
pool cjj1
return
else{
pool cjj2
when client::accpt
xxxxxx
1:if I want the traffic jump out of the irule when match help,it make sense to use return ,right?
if only one event here,it is no need to use return ,right?
2:I want to change the url to http://[HTTP::HOST][HTTP::uri] and send it to pool cjj1
does it work in my irule ?
pool cjj1
return
else{
pool cjj2
Hi,can some one help me ?
The HTTP::redirect command immediately sends the redirect response to the client. You can’t set a pool after issuing this command. You are sending the client back through your loadbalancer on a new request.
Also, if $uri = [HTTP:uri], then you will be in a redirect loop since you are not altering the client request when you redirect them. If $uri != [HTTP::uri], then you need an “elseif” clause that catches the new request and uses pool cjj1.
So, like this:
if { $uri starts_with “/help/” } {
HTTP::redirect “http://[HTTP::host][HTTP::uri]”
elseif { some new condition that matches your redirected request } {
pool cjj1
else {
pool cjj2
I haven’t used “return” so I won’t advise on its use.
Richard
thank richard so much
Keep in mind that return does not exit the iRule, only the event context that it’s fired in. This means in an iRule with multiple events, return does not stop the rest of the events from processing. It merely stops the processing of the current event.
Colin
Colin,
That’s really good to know. So, if you wanted to bail on the rule altogether, would something like this work?
if { some_condition } {
set bail_on_rule “true”
when HTTP_RESPONSE {
if { $bail_on_rule equals “true” } {
event disable
else {
other_stuff
Do variables live between events in the same rule? Is there an easier (maybe built in) way of doing this?
Richard
edit: lost my psuedo-code on posting
There isn’t a way to stop the iRule processing as a whole, really. The closest you can come is “event disable all”, but that’s scoped to the connection as a context. That means that if you fire an event disable (or an event disable all) you’re turning off that event for all iRules on that connection, not just the iRule it was fired within.
There are some logic tricks you can play with things like an info exists at the top of every event in an iRule that will make it behave the way you want, but there isn’t a specific command that exits the iRule.
Colin
