When I use iControlInterfaces.getLocalLBVirtualServer().get_list(), it only return the virtual created manually, but not the one created with iApp.
Someone replied here : DevCentral - An F5 Technical Community that we should use : System.Session.set_recursive_query_state()
How do I get the object system ?
Thanks.
I found code example in PS but not in Java and it appear there is no javadoc…
I found it, it’s the SystemSession, part of the iControl Interfaces :
iControl.Interfaces icInterfaces = new iControl.Interfaces();
icInterfaces.initialize(BigIPHostname, login, password) ;
try {
icInterfaces.getSystemSession().set_recursive_query_state(CommonEnabledState.STATE_ENABLED) ;
} catch (Exception E) {
web.println("Error while icInterfaces.getSystemSession().set_recursive_query_state(CommonEnabledState.STATE_ENABLED)") ;
web.println(E.toString()) ;
