Retrieving active NAT translations using iControl
We are planning to license the CGNAT module. One of the questions was whether iControl support retrieving a representation (preferably JSON or XML) of the active NAT translations.
So far i have come across the following interfaces.
DevCentral - An F5 Technical Community DevCentral - An F5 Technical Community DevCentral - An F5 Technical Community
Does anyone have any experience with the CGNAT module? Could really use some inputs.
Thanks.
Something like this: http://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/restapi/restapi/RESTAPInat.html58167
Hi aj,
you are probably aware of how to dump the detailled connection table (including all translation information) via tmsh:
tmsh show sys conn  all-properties
But I´m not aware of a equivalent via API.
As far as I can say the common approach is to log the connection details in real-time to a remote log server by using the HSL (high speed logging) capabilities.
Thanks, Stephan
