Restriction on IP source AND uri dest
Hello
I need to limit the access to some specific uri containing /wps/wcm/.*connect/iww_. to 10.0.0.0/8 ip range : except this specif web pages on Pool_WCM_Rendering_HTTP, all the website has to be accessible by anybody whatever his source ip.
for the time being, I’am using the following irule :
if {[HTTP::host] equals “wcm.bureauveritas.com”} {
pool Pool_WCM_Authoring_HTTP
pool Pool_WCM_Rendering_HTTP
and I try now to implement something like :
} elseif { not [IP::addr [IP::client_addr] 10.0.0.0/8 ] AND [HTTP::uri] contains “/wps/wcm/.*connect/iww_.*” } {
reject
else {
but the syntax is not correct : could you help me finding the correct syntaxt ? Is the best approach to filter as requested ?
Stephane Creuze
Stephane,
I am not positive this is what you want, but this iRule should look for the extra wcm.bureauveritas.com, your regular expression, and the internal IP address range. If all are true, then it will apply the rendering pool. Elsewise, if it sees wcm.bureaveritas.com and nothing else it will send it down the other pool.
Thanks,
-Andrew
besides regex, you may use this string match.
string match -nocase “/wps/wcm/*connect/iww_*” [HTTP::uri]
just my 2c.
