Hi All,
please need your Help
Our situation is as follows:
we had a cluster 2x6900 series, one of the box is out of service we want configure a box 3600 series and injected it LTM configuration from box 6900 which is in production
I tried this command but without result
tmsh load /sys ucs no-license
is that there is another solution to the recovered LTM configuration between two different box
we are really in a critical situation and we absolutely recouped the LTM configuration on the box 3600 series.
thank u in advance for your time
BR, KOR
Can you elaborate on ‘…without result’ please?
I think you also need to use the -no-platform-check parameter.
nathe
April 3, 2014, 3:16pm
3
KOR,
You mention the command “tmsh load /sys ucs no-license” I take it you also included the UCS file name too as part of the command? i.e. “tmsh load /sys ucs backup.ucs no-license”
WLB is right, you can use no-platform-check too.
This does presume you’re on TMOS v11. With TMOS v10 there is a “rma” switch instead.
Rgds
N
You should be able to just establish a new Device Trust, and then one way SYNC the configuration from the 6900 to the 3600.
The 3600 must be licensed/provisioned identical to the 6900, and there are probobly other caveats as well.
It sounds like you are trying to create an HA pair, rather than restore a UCS from one platform on another. So check into the Device Cluster configuration details for 11.2 and see if that fits your requirements.
Good Luck - Chris.
Hi Nathan,Chris thank you for time and help what we want to do is to have the 3600 box as secondary, is not gonna mounted cluster that’s why I need to recover the LTM config. Here are the results of the two command no-license and no-plateformecheck. error returned on /var/log/ltm Apr 6 04:22:01 Ooredoo warning tmsh[20823]: 01420007:4: Certificate ‘CN=www.orientation.esi.dz,OU=ESI,O=Ecole Nationale Superieure d’Informatique,L=Alger,ST=Oued Smar,C=DZ’ in file /Common/THAWTEE2012.crt expired on May 29 23:59:59 2013 GMT Apr 6 08:46:22 Ooredoo err mcpd[5707]: 01070734:3: Configuration error: Invalid mcpd context, folder not found (/Common/var/log/ltm) Apr 6 09:29:46 Ooredoo err mcpd[5707]: 01020036:3: The requested BIGdb variable (ucs_no_platform_check) was not found. Apr 6 09:30:03 Ooredoo warning mcpd[5707]: 010712e9:4: ucs_no_platform_check is not in BigDB.dat. Apr 6 09:30:09 Ooredoo info tmsh[4675]: Begin config install operation: /var/local/ucs/Config_1_04_2014.ucs Apr 6 09:30:10 Ooredoo notice root: /usr/bin/perl /usr/local/bin/im -exclfrom -q -force /var/local/ucs/Config_1_04_2014.ucs ==> /usr/bin/bigstart stop named Apr 6 09:30:11 Ooredoo notice mcpd[5707]: 01070410:5: Removed subscription with subscriber id named Apr 6 09:30:13 Ooredoo notice root: /usr/bin/perl /usr/local/bin/im -exclfrom -q -force /var/local/ucs/Config_1_04_2014.ucs ==> /usr/bin/bigstart stop zrd Apr 6 09:30:13 Ooredoo info install_ucs.pm: Install the license file from UCS onto the system. Apr 6 09:30:18 Ooredoo notice root: /usr/bin/perl /usr/local/bin/im -exclfrom -q -force /var/local/ucs/Config_1_04_2014.ucs ==> /usr/bin/bigstart start named Apr 6 09:30:18 Ooredoo notice root: /usr/bin/perl /usr/local/bin/im -exclfrom -q -force /var/local/ucs/Config_1_04_2014.ucs ==> /usr/bin/bigstart start zrd Apr 6 09:30:19 Ooredoo notice sod[5702]: 010c0044:5: Command: running disable zrd bigstart. Apr 6 09:30:19 Ooredoo warning mcpd[5707]: 01070267:4: Dossier warning 09 14. Apr 6 09:30:19 Ooredoo err mcpd[5707]: 01070266:3: Dossier error 01 04 04 04 04 04 04 04 04 04 04 04 04 04 08 12. Apr 6 09:30:19 Ooredoo notice mcpd[5707]: 01070419:5: Platform initialization phase triggered. Apr 6 09:30:19 Ooredoo warning mcpd[5707]: 01070267:4: Dossier warning 09 14. Apr 6 09:30:19 Ooredoo err mcpd[5707]: 01070266:3: Dossier error 01 04 04 04 04 04 04 04 04 04 04 04 04 04 08 12. Apr 6 09:30:19 Ooredoo info promptstatusd[4636]: 01460007:6: mcp phase none Apr 6 09:30:19 Ooredoo info promptstatusd[4636]: 01460007:6: mcp last load status in progress Apr 6 09:30:19 Ooredoo info promptstatusd[4636]: 01460007:6: mcp phase base Apr 6 09:30:19 Ooredoo info promptstatusd[4636]: 01460007:6: mcp last load status high load in progress Apr 6 09:30:20 Ooredoo emerg mcpd[5707]: 01070608:0: License is not operational (expired or digital signature does not match contents). Apr 6 09:30:21 Ooredoo info mprov:7151:: Invoked as: /usr/bin/mprov.pl (pid=7151) --quiet --legacy Apr 6 09:30:22 Ooredoo info mprov:7151:: Provisioning (legacy update) successful. Apr 6 09:30:23 Ooredoo notice mcpd[5707]: 01071038:5: Unit key read from the hardware. Apr 6 09:30:23 Ooredoo notice mcpd[5707]: 01071038:5: Loading keys from the file. Apr 6 09:30:23 Ooredoo err mcpd[5707]: 010713d0:3: Symmetric Unit Key decrypt failure - decrypt failure Apr 6 09:30:23 Ooredoo notice mcpd[5707]: 01071029:5: Symmmetric Unit Key decrypt Apr 6 09:30:23 Ooredoo notice mcpd[5707]: 01071027:5: Master key OpenSSL error: 5707:error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt:evp_enc.c:330: Apr 6 09:30:23 Ooredoo notice mcpd[5707]: 01071038:5: Attempting Master Key migration to new unit key. Apr 6 09:30:26 Ooredoo notice mcpd[5707]: 01071038:5: Reloading the RSA unit to support config roll forward. Apr 6 09:30:26 Ooredoo notice mcpd[5707]: 01071038:5: Loading keys from the file. Apr 6 09:30:27 Ooredoo err mcpd[5707]: 01070356:3: Cookie persistence feature not licensed. Apr 6 09:30:27 Ooredoo err mcpd[5707]: 01070356:3: Destination address persistence feature not licensed. Apr 6 09:30:27 Ooredoo err mcpd[5707]: 01070356:3: Universal and hash persistence feature not licensed. Apr 6 09:30:27 Ooredoo err mcpd[5707]: 01070356:3: MSRDP persistence feature not licensed. Apr 6 09:30:27 Ooredoo err mcpd[5707]: 01070356:3: SIP persistence feature not licensed. Apr 6 09:30:27 Ooredoo info mcpd[5707]: 01070356:6: Per-invocation log rate exceeded; throttling. Apr 6 09:30:27 Ooredoo err mcpd[5707]: 01070356:3: SNAT feature not licensed. Apr 6 09:30:28 Ooredoo info promptstatusd[4636]: 01460007:6: mcp phase base Apr 6 09:30:28 Ooredoo info promptstatusd[4636]: 01460007:6: mcp last load status in progress Apr 6 09:30:28 Ooredoo err tmsh[7155]: 01420006:3: Loading configuration process failed. Apr 6 09:30:28 Ooredoo err load_config_files: “/usr/bin/tmsh -n -g load sys config partitions all” - failed. -- Loading system configuration… /defaults/app_template_base.conf /defaults/config_base.conf /config/low_profile_base.conf /defaults/wam_base.conf /usr/share/monitors/base_monitors.conf /config/daemon.conf /config/profile_base.conf /defaults/fullarmor_gpo_base.conf /defaults/classification_base.conf Loading configuration… /config/partitions/CRM/bigip_base.conf /config/partitions/CRM/bigip.conf /config/bigip_base.conf /config/bigip_user.conf /config/bigip.conf /config/partitions/DNS/bigip.conf /config/partitions/HLR/bigip.conf /config/partitions/HMC/bigip.conf /config/partitions/LDAP/bigip.conf /config/partitions/VAS/bigip.conf /config/partitions/VAS2/bigip.conf 01070356:3: SNAT feature not licensed. Unexpected Error: Loading configuration process failed. Apr 6 09:30:29 Ooredoo warning mcpd[5707]: 01071423:4: High config load failed during a license reset. Fallback to base load. Apr 6 09:30:29 Ooredoo info promptstatusd[4636]: 01460007:6: mcp phase platform Apr 6 09:30:29 Ooredoo info promptstatusd[4636]: 01460007:6: mcp last load status base load in progress Apr 6 09:30:31 Ooredoo notice mcpd[5707]: 01071038:5: Unit key read from the hardware. Apr 6 09:30:31 Ooredoo notice mcpd[5707]: 01071038:5: Loading keys from the file. Apr 6 09:30:31 Ooredoo err mcpd[5707]: 01070307:3: Invalid interface 1.9 Apr 6 09:30:31 Ooredoo info promptstatusd[4636]: 01460007:6: mcp phase platform Apr 6 09:30:31 Ooredoo info promptstatusd[4636]: 01460007:6: mcp last load status in progress Apr 6 09:30:31 Ooredoo err tmsh[7192]: 01420006:3: Loading configuration process failed. Apr 6 09:30:31 Ooredoo err load_config_files: “/usr/bin/tmsh -n -g load sys config partitions all base” - failed. -- Loading system configuration… /defaults/app_template_base.conf /defaults/config_base.conf /config/low_profile_base.conf /defaults/wam_base.conf Loading configuration… /config/partitions/CRM/bigip_base.conf /config/bigip_base.conf /config/bigip_user.conf 01070307:3: Invalid interface 1.9 Unexpected Error: Loading configuration process failed. Apr 6 09:30:32 Ooredoo err mcpd[5707]: 01070422:3: Base configuration load failed. Apr 6 09:30:32 Ooredoo info promptstatusd[4636]: 01460007:6: mcp phase platform Apr 6 09:30:32 Ooredoo info promptstatusd[4636]: 01460007:6: mcp last load status base failed Apr 6 09:30:33 Ooredoo info install_ucs.pm: Configuration loading error: base-config-load-failed Apr 6 09:30:34 Ooredoo err tmsh[4675]: 01110001:3: Error running config install
OK, it looks like you have multiple issues with this approach.
SSL Certs
Device Certs
Dossier
Licensing
Just to name a few based on all the errors you posted.
I’m going to recommend that you switch gears completely, and try using the Single Configuration File. The SCF only cares about the big-ip networking and load balancing objects. This will probably be easier than trying to override the UCS code to force a config load on a different box.
Give this a look, I think it will be much closer to what you want to do. support.f5.com , Solution SOL13408:
Short of this working, you will probably have to beg F5 Support to help you with config files, and a host of TMSH commands to load/merge config files.
Good Luck !
-Chris.
