REST Call Timeout - Python SDK
Running 11.6.0 HF5 the following Python SDK call:
mgmt.tm.util.bash.exec_cmd(
    command='run',
    utilCmdArgs="-c 'tmsh save /sys ucs /var/local/ucs/f5-create-backup-python.ucs'",
…throws this exception:
Traceback (most recent call last):
  File "", line 1, in
  File ".../f5env/lib/python3.6/site-packages/f5/bigip/tm/util/bash.py", line 55, in exec_cmd
    return self._exec_cmd(command, **kwargs)
  File ".../f5env/lib/python3.6/site-packages/f5/bigip/mixins.py", line 257, in _exec_cmd
    self._meta_data['uri'], json=kwargs, **requests_params)
  File ".../f5env/lib/python3.6/site-packages/icontrol/session.py", line 287, in wrapper
    raise iControlUnexpectedHTTPError(error_message, response=response)
icontrol.exceptions.iControlUnexpectedHTTPError: 400 Unexpected Error: Bad Request for uri: https://my.ltm.com:443/mgmt/tm/util/bash/
Text: '{
    "code":400,
    "message":"remoteSender:10.1.1.1,
               uri:http://localhost:8110/tm/util/bash/,
               method:POST ",
    "originalRequestBody":"{
        \\"utilCmdArgs\\": \\"-c \'tmsh save /sys ucs /var/local/ucs/f5-create-backup-python.ucs\'\\",
        \\"command\\": \\"run\\"",
    "referer":"10.1.1.1",
    "restOperationId":28795163,
    "errorStack":[
        "java.util.concurrent.TimeoutException: remoteSender:10.1.1.1,
            method:POST ",
        "at com.f5.rest.common.RestRequestSender.checkExpiredOperations(RestRequestSender.java:505)",
        "at com.f5.rest.common.RestServer.checkAndExpirePendingWorkerOperations(RestServer.java:854)",
        "at com.f5.rest.common.RestServer.access$400(RestServer.java:43)",
        "at com.f5.rest.common.RestServer$3.run(RestServer.java:822)",
        "at com.f5.rest.common.ScheduleTaskManager$2.run(ScheduleTaskManager.java:105)",
        "at java.util.TimerThread.mainLoop(Timer.java:555)",
        "at java.util.TimerThread.run(Timer.java:505)\\n"
I’m using util.bash to make the call because of the old TMOS version. This same script works fine on our other 11.6.0 LTMs - two of them are failing and under much heavier load.
Is there a way to increase this timeout?
I use this method to increase the timeout using the REST API, so you may be able to translate it for the SDK. (sorry Python SDK isn’t my strong point)
curl -X POST \
  'https://bigip1.local/mgmt/shared/authn/login' \
  -H 'Cache-Control: no-cache' \
  -H 'Content-Type: application/json' \
  -d '{
    "username":"admin",
    "password":"admin",
    "loginProviderName": "tmos"
This will respond with a JSON body containing a token (token.token) Use this token on a second request to extend your timeout. If your token was ABCDEFGHIJKMLNOPQRSTUVWXYZ, your second request would look like this:
curl -X PATCH \
  https://bigip1.local/mgmt/shared/authz/tokens/ABCDEFGHIJKMLNOPQRSTUVWXYZ \
  -d '{
    "timeout":"36000"
