Resource Provisioning on a 7250 appliance.
The new 7250 boxes come licensed with LTM, but we will only be using the appliances for APM. We are working on upgrading from 6900 to 7250 appliances. What resource Provision is required to be turned on? We are Licensed for: LTM, APM, vCMP, AVR and AAM, but will only use the boxes for APM with no vCMP.
LTM is a nice thing to have, you can work without it but then you are limited to 1 member in a pool. (and there are more limitations)
So I would provision both LTM and APM.
Cheers,
Kees
