Resource Cloaking
How do I configure resource Cloaking ?
Is there any document available on the same?
I’m assuming you are referring to signature cloaking via iRules. There’s a sample over in CodeShare titled “Web Server Signature Cloaking”. You might want to take a look at over there for a usage.
You can also find documentation of the “HTTP::header sanitize” command in the “Manipulating Header or Content Data” iRule tech tip in the “Docs and Tips” section.
Next time, if you could post iRules related questions in the appropriate iRules forum you’ll get a quicker response.
-Joe
Hi Joe,
Thanks for your quick reply, still i am unable to figure it out.
Can you elaborate your point, will you able to explain me.
Thanks in advance. Sanket
Were you not able to find the information I mentioned? A sample iRule as well as documentation of the command was in there.
If you can explain specifically what you want to do, we might be able to elaborate a bit more.
-Joe
