Firstly I’m running 10.2.0 1755.1
Hoping someone can help me here, I want to use RESOLV::lookup to do reverse lookups on addresses for some logging.
My problem is I get no result from a lookup on an address, I do get a result from a lookup on a FQDN.
I have a DNS Server configured, nslookup, host and dig all work great.
I’ve also tried NAME:lookup, this also fails.
Querying A records seems to work fne, but PTR dont work. I’ve run tcpdump while executing my iRule, and I see the PTR query go out - and I see a response! (also happens to be identical traffic to when I do a manual nslookup) … but still no output from RESOLV::lookup (or NAME::lookup for that matter)
I’ve searched ask.f5 and the forum, I found the references below…neither of them help unfortunetly (tried turning on recursive and the tmm_base config is now ‘out-of’the-box’ with 10…
http://devcentral.f5.com/Wiki/defau…ngDNS.html
http://devcentral.f5.com/Community/…fault.aspx
Here is an iRule I’ve been using to test…
when CLIENT_ACCEPTED {
set client_addr [IP::client_addr]
log local0. “$client_addr”
log local0. “[RESOLV::lookup @10.163.134.22 [IP::client_addr]]”
log local0. “[RESOLV::lookup @10.163.134.22 -ptr [IP::client_addr]]”
log local0. “[RESOLV::lookup @10.163.134.22 -ptr “10.178.78.165”]”
log local0. “[RESOLV::lookup @10.163.134.22 -ptr 10.178.78.165]”
log local0. “[RESOLV::lookup @10.163.134.22 10.178.78.165]”
log local0. “[RESOLV::lookup @10.163.134.22 “host.domain.com”]”
The only result I get is from the last line …
Has anyone struck this?
J
