Hello
I want to put my F5 Viprion back to factory defaults.
I tried the method with Init 1 then sys-reset but I get this error:
h-3.00 sys-reset
tar: ./etc/fstab: Not found in archive
tar: Error exit delayed from previous errors
Unrecognized device mount: /dev/vg-db-hdc/set.1.root /
Exceptions to standard device mounts must be removed before sys-reset can proce.
How to I restore it back to defaults?
Thanks for any help.
