Hi, Community:
is that possible to reset snmp counter F5-BIGIP-SYSTEM-MIB::sysStatClientMaxConns, when I do performance test, i need to reset it to get correct value eachtime.
Grei
Hi, Community:
Grei
I could not find a MIB just for client max conns. I used this string to look for reset MIB’s:
snmpwalk -v 2c -c public localhost F5 | grep -i reset | more
I tried a couple but could not get that MIB to reset. I have used this MIB in the past to reset all stats:
snmpset -c private -v 1 localhost F5-BIGIP-SYSTEM-MIB::sysStatResetStats.0 i 1
Of course you would need to define a writeable access string available to localhost on the LTM prior to running the snmpset command.
Hope this helps.
