Requiring an SSL Certificate for Parts of an Application
In the post: http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&forumid=5&postid=9448
I found a reference to this article:
Tuesday, December 07, 2004
By Rick Masters
http://devcentral.f5.com/Default.aspx?tabid=29&mid=356&ctl=ArticleView&articleId=39
But the URL to the article shown above is not working.
What this article mentions is what exactly I need to do. Also, it seems that the steps provided in the article are not working with BIG-IP 9.2.x.
So, has this article been updated? If so, can someone point me to the updated article or a link to any article/post that achieves the same?
The post you reference notes the bugs were logged in CR58837 and CR68339. Searching for those CR’s on AskF5 leads to SOL6605 (Click here), which states that the issue was fixed in 9.2.4.
I would expect that the issue has been fixed in 9.2.4, 9.3.0 and 9.4.0.
What version are you running? If you’re on 9.2.0 - 9.2.3 are you able to upgrade? If you’re on a version that the CR was fixed in, have you tested the rule? If so, are you running into any issues?
Aaron
